Basic Vector Data Analysis with GRASS
vector
beginner
intermediate
Python
Learn the core vector operations in GRASS: exploring attributes, selecting by attribute and by location, buffering, overlay, and counting features per area.
Author
Rajveer Bishnoi
Published
July 5, 2026
Modified
October 22, 2026
Introduction
Vector data represents geographic features as points, lines, and areas, each linked to a table of attributes. GRASS has a large family of v.* tools for working with them. This tutorial introduces the operations you will reach for most often, using a single worked example: analyzing how schools in central Raleigh, North Carolina relate to major roads and ZIP code areas.
Along the way we will:
  • explore a vector map and its attribute table,
  • clip a map to the study area with v.clip,
  • select by attribute with v.extract,
  • buffer features with v.buffer,
  • select by location with v.select,
  • perform spatial operations with v.overlay, and
  • count features per area with v.vect.stats.
NoteDemo dataset
This tutorial uses the GRASS North Carolina sample dataset (raleigh_northcarolina_usa_epsg6542), which includes schools (points), roads (lines), and zipcodes (areas). The data lives in the PERMANENT mapset, and we work in the empty mapset_1 that comes with it.
NoteHow to run this tutorial
The code uses the GRASS Python API in a Jupyter notebook. If you are new to running GRASS from Python, see the Get started with GRASS & Python tutorial. Every step also works from the GRASS GUI or command line; just use the tool name (for example v.buffer) with the same parameters.
Setup and exploration
Start a GRASS session in mapset_1 and set the computational region to the dataset’s default, a 24 x 13.5 km window over central Raleigh. For vector-only work the region mainly controls what the maps display, but we will also use it to clip a layer below.
import sys
import subprocess
sys.path.append(
    subprocess.check_output(["grass", "--config", "python_path"], text=True).strip()
import grass.script as gs
import grass.jupyter as gj
from grass.tools import Tools
session = gj.init("~/grassdata/raleigh_northcarolina_usa_epsg6542/mapset_1")
tools = Tools()
tools.g_region(flags="d")
NoteGRASS version
The examples use the grass.tools API (the Tools class), introduced in GRASS 8.5. On earlier versions you can run the same tools with gs.run_command("v.buffer", ...).
Before analyzing a layer, it helps to know what it contains. v.info reports the feature types and counts, and its -c flag lists the attribute columns.
# Feature summary (points, lines, areas ...)
print(tools.v_info(map="schools", flags="t").text)
# Attribute columns
print(tools.v_info(map="schools", flags="c").text)
schools has 61 point features. Let’s look at the attribute table itself. v.db.select can return the table as JSON, which pandas turns into a tidy table:
import pandas as pd
pd.DataFrame(
    tools.v_db_select(
        map="schools",
        columns="school_nam,phys_city,num_teach,elem,middle,high",
        format="json",
    )["records"]
).head()
school_nam phys_city num_teach elem middle high
Adams Elementary Cary 54 yes
Exploris Raleigh 17 yes
Athens Drive High Raleigh 128 yes
Aversboro Elementary Garner 39 yes
Longview Raleigh 27 yes yes
The elem, middle, and high columns are set to yes for each level a school teaches. A school can teach more than one: Longview covers grades 6 to 12, so it has both middle and high set. We use these columns next to select schools by attribute.
The study area is a rectangle over central Raleigh, and the schools and roads stop at its edge. The ZIP code areas do not: they are whole, and 13 of the 15 reach beyond it. Counting schools per whole ZIP code would undercount the ones that only partly overlap the study area, because their schools outside it are not in the data. v.clip with the -r flag clips the ZIP code areas to the computational region, so we only work with the part we have data for:
tools.v_clip(input="zipcodes", output="zipcodes_raleigh", flags="r")
Let’s draw an overview map: the clipped ZIP code areas, the roads, and the schools. In grass.jupyter, a Map object collects display layers and renders them together.
overview = gj.Map(width=500)
overview.d_vect(map="zipcodes_raleigh", type="area",
                fill_color="235:235:235", color="180:180:180")
overview.d_vect(map="roads", color="190:190:190", width=1)
overview.d_vect(map="schools", icon="basic/circle", size=7,
                fill_color="200:30:30", color="white")
overview.d_barscale(flags="n", at=(1, 10), length=5, units="kilometers",
                    bgcolor="white")
overview.show()
Central Raleigh: ZIP code areas (gray), all roads, and the 61 schools (red).
Selecting by attribute
To keep just the elementary schools (elem = 'yes'), use v.extract with a SQL where clause.
tools.v_extract(input="schools", output="elementary", where="elem = 'yes'")
print(tools.v_info(map="elementary", flags="t").text)  # points=31
The same tool picks out the major roads. The roads come from OpenStreetMap, where the highway column classifies each segment; motorways, trunk roads, and primary roads make up the major road network.
tools.v_extract(input="roads", output="roadsmajor",
                where="highway IN ('motorway', 'trunk', 'primary')")
attr_map = gj.Map(width=500)
attr_map.d_vect(map="zipcodes_raleigh", type="area",
attr_map.d_vect(map="roadsmajor", color="90:90:90", width=1)
attr_map.d_vect(map="schools", icon="basic/circle", size=6,
                fill_color="180:180:180", color="none")
attr_map.d_vect(map="elementary", icon="basic/circle", size=8,
                fill_color="30:120:200", color="white")
attr_map.d_barscale(flags="n", at=(1, 10), length=5, units="kilometers",
                    bgcolor="white")
attr_map.show()
Elementary schools (blue) selected from all schools (gray) by attribute.
Buffering
A buffer is an area of a given radius around features. Here we buffer the major roads by 500 m with v.buffer to represent an “along a major road” corridor. The result is an area map.
tools.v_buffer(input="roadsmajor", output="road_buffer", distance=500)
buffer_map = gj.Map(width=500)
buffer_map.d_vect(map="zipcodes_raleigh", type="area",
buffer_map.d_vect(map="road_buffer", type="area", fill_color="255:200:120", color="none")
buffer_map.d_vect(map="roadsmajor", color="120:70:20", width=1)
buffer_map.d_barscale(flags="n", at=(1, 10), length=5, units="kilometers",
                      bgcolor="white")
buffer_map.show()
A 500 m buffer (orange) around the major roads.
Selecting by location
Now we combine two layers spatially: v.select keeps features of one map based on their spatial relationship to another. With operator=overlap, we keep the elementary schools that fall inside the road buffer.
tools.v_select(ainput="elementary", binput="road_buffer",
               output="schools_near", operator="overlap")
print(tools.v_info(map="schools_near", flags="t").text)  # points=16
16 out of the 31 elementary schools lie within 500 m of a major road. Only 4 of them are that close to a motorway or trunk road; the other 12 qualify because of a primary road.
near_map = gj.Map(width=500)
near_map.d_vect(map="zipcodes_raleigh", type="area",
near_map.d_vect(map="road_buffer", type="area", fill_color="255:230:200", color="none")
near_map.d_vect(map="roadsmajor", color="150:110:60", width=1)
near_map.d_vect(map="elementary", icon="basic/circle", size=7,
                fill_color="150:150:150", color="none")
near_map.d_vect(map="schools_near", icon="basic/circle", size=9,
                fill_color="20:150:60", color="white")
near_map.d_barscale(flags="n", at=(1, 10), length=5, units="kilometers",
                    bgcolor="white")
near_map.show()
Elementary schools within 500 m of a major road (green) versus the rest (gray).
Overlaying layers
v.overlay combines two area maps with set operations. With operator=and we get the intersection, the part of the road corridor that falls within each ZIP code area. The output keeps the attributes of both inputs (prefixed a_ and b_).
tools.v_overlay(ainput="road_buffer", binput="zipcodes_raleigh",
                operator="and", output="buffer_by_zip")
overlay_map = gj.Map(width=500)
overlay_map.d_vect(map="zipcodes_raleigh", type="area",
overlay_map.d_vect(map="buffer_by_zip", type="area",
                   fill_color="120:180:220", color="80:80:80", width=1)
overlay_map.d_barscale(flags="n", at=(1, 10), length=5, units="kilometers",
                       bgcolor="white")
overlay_map.show()
The road buffer intersected with the ZIP code areas; polygons are split at ZIP boundaries.
Because each piece now carries its ZIP code, we can measure how much of each ZIP code is within reach of a major road. v.to.db computes the area of every polygon, and a grouped SQL query with db.select sums it per ZIP code:
tools.v_to_db(map="buffer_by_zip", option="area", columns="reach_area", units="kilometers")
# db.select also returns JSON, so the same pandas pattern works here
pd.DataFrame(
    tools.db_select(
        sql="SELECT b_ZCTA5CE10 AS zip_code, "
            "ROUND(SUM(reach_area), 1) AS reach_km2 "
            "FROM buffer_by_zip GROUP BY b_ZCTA5CE10 ORDER BY reach_km2 DESC",
        format="json",
    )["records"]
).head(6)
zip_code reach_km2
27610 42.6
27606 27.7
27603 22.7
27607 14.4
27529 14.1
27511 10.9
ZIP code 27610 leads because it has both the most area inside the study area and the most kilometers of major road.
Counting features per area
A common summary is “how many points fall in each area?” v.vect.stats counts the points of one map within the areas of another and writes the result to the area map’s attribute table. We first create a copy of the ZIP codes map with g.copy so the original is untouched.
tools.g_copy(vector=("zipcodes_raleigh", "zip_counts"))
tools.v_vect_stats(points="schools", areas="zip_counts", count_column="n_schools")
Each ZIP code now has an n_schools value (ranging from 0 to 16 here). We map it as a choropleth with d.vect.thematic, using quantile classes so each color holds a similar number of areas.
choropleth = gj.Map(width=500)
choropleth.d_vect_thematic(
    map="zip_counts", column="n_schools", algorithm="qua", nclasses=5,
    colors="240:249:255,189:215:231,107:174:214,49:130:189,8:81:156",
choropleth.d_vect(map="roadsmajor", color="120:120:120", width=1)
choropleth.d_barscale(flags="n", at=(1, 10), length=5, units="kilometers",
                      bgcolor="white")
choropleth.show()
Schools per ZIP code area, classified into five quantiles from light (few) to dark (many).
See also a dedicated tutorial on Making Thematic Maps.
Summary
Using the schools, roads, and ZIP codes of central Raleigh, we have worked through the core vector toolkit in GRASS:
  • exploring features and attributes with v.info and v.db.select,
  • clipping a map to the study area (v.clip),
  • selecting by attribute (v.extract) and by location (v.select),
  • buffering (v.buffer) and overlaying (v.overlay) layers, and
  • counting points per area (v.vect.stats) for a thematic map.
