Skip to main content
Get started with GRASS GUI
beginner
GUI
5 simple steps to get you started with GRASS using its graphical user interface (GUI).
Author
Veronica Andreo
Published
March 19, 2024
Modified
November 11, 2026
In this notebook we will walk you through 5 simple steps to get you started with GRASS using its graphical user interface (GUI).
If you want to use Python or R, check out tutorials to get started with GRASS in Jupyter Notebooks or R.
Step 1: Install the software
GRASS is available on Windows, Linux and macOS. The binaries for Windows and macOS can be found at https://grass.osgeo.org/download/. We recommend using the current release version.
GRASS package is available for many Linux distributions. Let’s see an example of how to install GRASS on Linux/Ubuntu:
sudo add-apt-repository ppa:ubuntugis/ubuntugis-unstable
sudo apt-get update
sudo apt-get install grass grass-gui grass-dev
Step 2: Open GRASS
Just double click on the GRASS icon. You will get the GUI and terminal. You can use GRASS tools in either. It’s a matter of taste, task on hand and habit, too.
GRASS Graphical User Interface and terminal
The GRASS GUI has a single window layout by default, but it is also possible to minimize and/or dock/undock the panels. On the left, you can find the data browser which allows you to navigate through your projects and data, and the layers panel showing displayed layers. The panel in the middle is the map display. You can add additional map displays if you need using . Finally, on the right there are multiple tabs where you can find a searchable tools’ tree similar to the Processing toolbox in QGIS, a console where you can type GRASS commands, the history of executed commands in case you want to re-run a task and a simple Python console where you can use the GRASS Python API.
Note
See this example of the GRASS single window GUI with multiple map displays:
Step 3: Create a project
When you open GRASS for the first time, a new directory is created in your home folder. This directory is called grassdata by default and stores all your GRASS projects. GRASS projects are simply folders storing your geospatial data with common coordinate reference system (CRS), ensuring consistency of your data. At the project level, data is further organized into subprojects called mapsets, which you can use to manage different subregions or analyses within a project. Each project contains a special mapset called PERMANENT, which is used to store source datasets for your analysis that can be easily accessed from other mapsets.
Within the grassdata directory you will see a sample project called world_latlong_wgs84 which contains the PERMANENT mapset, with a sample vector layer. While there are other sample data sets that you could download to play around with GRASS and test it, you most likely have some data of your own that you want to process and analyse. Therefore, the third step is to create a new project and select its CRS by its name, EPSG code or take it from your input data. Let’s see a simple way to create a project in GRASS GUI. You can either click over “Create new project” in the info bar or use icon.
Create a new GRASS project
Step 4: Import your data
Once you have created your GRASS project, you’ll notice it contains the PERMANENT mapset inside. You can import your data there or optionally you could create other mapsets to organize your work.
Why do we need to import data? GRASS has a native format for raster and vector data to facilitate robust and efficient analysis and manipulation of geospatial data. One advantage of this structure is that you can easily zip your mapsets or projects to share with your colleagues. And guess what? Not only data will be there but also the history of commands you have executed on them!
So, how do we import data? Let’s see an example for raster and vector data formats. For imports with optional re-projection, you can use and icons from the Data panel bar.
In the first case, we import 10m resolution bands from Copernicus Sentinel 2 scenes that can be found here. Note that we can import all files within a directory if we specify the extension of such files, jp2 in this case.
In another example, we import a GeoPackage with different CRS. Data will be automatically reprojected.
Maps will be added to the layer tree and displayed automatically.
Step 5: Set the computational region
The last important step, especially if you are working with raster data, is to set the computational region. This is the extent and resolution of your region of interest or study area, and it will affect all your raster processing, i.e., output rasters will have their extent and spatial resolution equal to the computational region. You can set the computational region to the extent of a vector map, to the extent and resolution of a raster map or manually introducing the north, south, east, and west coordinates.
Why do we need a computational region? When combining data with different resolution and extents, it helps keeping results consistent. Also, raster data might be large and running processes on them might take a while. Setting a smaller computational region allows you to test your algorithms and parameter values without the need to clip input maps, so once you are happy with the result, you can run the process for the whole raster extent.
The computational region can be changed interactively from the map display by selecting a region with your mouse, or using the g.region tool both from the GUI and command line.
  • Interactive:
  • Using g.region from the contextual menu after right click on a layer:
  • Using g.region from the main menu in the GUI:
Note how commands are formed when you select options in the GUI. If you use the button, you can then paste these in a text file and set the basis of your protocol, which can then be generalized into a script or even your own GRASS tool.
  • From the console tab or in the terminal:
g.region -p raster=myraster
Getting help
There are several sources you can get help from:
You are ready! Enjoy!
The development of this tutorial was funded by the US National Science Foundation (NSF), award 2303651.
